i bought a perfex long travel lift kit, came with no instructions. the front brackets fit ok but the small tabs bent down touch the cv boot. the rear bracket fits in place but i have a problem. the bolt where the shock was mounted only holds half of the bracket. went i bolt the shock to lift bracket the bolt contacts the rear differential. i'm having bad luck with this kit. please help. picture of installed kit would also help. thank you
