I have to change pump on a 2001 500. can i just remove the side cover clutch is on or do i need to split whole motor. thanks
  1. Materials Needed.
  2. Step 1: Chock the wheels and set the emergency brake. ...
  3. Step 2: Jack up the vehicle and remove the wheels. ...
  4. Step 3: Disconnect the negative battery cable.
  5. Step 4: Drain the engine oil.
  6. Step 1: Remove the oil pan. ...
  7. Step 2: Remove the old oil pan gasket.
mobdro
Agreed?
