We've changed dozens & dozens of the front final shaft seals .. If it is just wet around the seal it wouldn't hurt to drive it as long as you keep an eye on the oil level .. The seal isn't hard to change ,just unbolt the front differential and slide it forward ,then remove the front drive shaft ..
