1 - 6 of 6 Posts
depends on how much oil we are takling about
have you been traveling somewhere with the bike recently?
a lot of moving around can cause oil to back up into the air box, which means someone overfilled it. that's what i was told anyway....
Discussion Starter · #5 ·
no its just been sitin in the garage. and the oil hasnt been changed reentley. i did stand it up on the back rack tho
don't leave it up on the back rack to long... You will see a little oil in the air box. I'd have to say no more than 5 mins. If your cleaning it get a pressure washer. works a lot faster! Now you will see a little oil from the air filter, it's should be red. Make sure and turn the fuel off too and let the motor burn off whats left in the fuel line b4 you put it up on the racks.
1 - 6 of 6 Posts
