1 - 6 of 6 Posts
Has anyone ever found a healthy amount of oil in the bottom of the air box. I use a K&N filter and was checking to see if needed to be cleaned and noticed some oil at the bottom of the airbox. I know I put oil on the filter when first installed and the filter did seem to still have a fair amount of oil on it, but it took 3 napkin type paper towel to absorb it. Also does anyone know when re-appliying oil to the filter should it also be sprayed on the inside??
have you replaced you oil any time soon? if so i bet you put too much oil in. also riding wheeles can make oil come in the air box.
Discussion Starter · #3 ·
No wheelies and oil was changed at the shop last spring!
Discussion Starter · #5 ·
Thanks for input I cleaned out the air box and will check the oil>
just got kn filter....they come oiled from the factory....only put oil in the inside if riding in extreme dusty conditions...if over oiled you need to clean and then reoil
1 - 6 of 6 Posts
