Oil and fluids
2527 Views 3 Replies 3 Participants Last post by  Crin
Howdy all, I just changed the oil in my Ruby and was curious if there is any other lub's I need to check. In the diff's or tranny? Or is it just oil and coolant? These may be kinda dumb questions but I havn't gotten my owners man yet and I just want to be sure.
Also how can I reset the LED display so it now longer says "Oil Change"?
Thanks in advance
C-rin
to reset change oil light hold both buttons on your POD display for like 5 sec it will go out.
QUOTE ("Crin":3n06tkwf)
Thanks in advance
C-rin
There is no seperate tranny oil, your engine oil lubricates the engine, clutch and tranny (2 drain plugs to drain the oil). Check the F&R diffs for water contamination and check coolant level. Other than brake fluid there are no other fluids and no grease zerks to worry about.
Kewl, Thanks!!
C-rin
