1995 Honda Foreman 400 TRX
So im not sure how to explain this but, when I'm riding and the engine is warm and i get to higher gears, my regular exhaust noise is suddenly replaced by an air suction noise or like its really muffled to almost no noise and theres less power. I checked the air box and air intake tube. Everything seems fine. Although i did notice my carb is leaking gas some where, could that be a reason for the noise? (Or lack of noise i should say)
Could be a broken baffle in the exhaust, had it happen to me on an older 450. Happened on a ride and once the muffler got a swift kick, the baffle moved enough to get the power back. Of course the baffle worked its way back to block the exhaust and it took a few more boots to get home! Pull the pipe and give it a shake, it might be loose enough to hear.
