2003 rubicon 500.
Solenoid trigger wire is dead, no click, nothing!
Also will not start with pull rope. Haven't pulled the plug to check for spark because it's such a pita but it ran 3-4 weeks ago when I parked it. I figure the 2 problems are likely related..
Followed the wiring harness best I could with removing the front fenders. Doesn't seem to be any breaks or chewed places. Pulled the handlebar switch apart and it's working and has power.
I wondered about the diode in the fuse box?
Tried testing It with an ohm meter.. I get a reading for a quick second and then it reads open...both sides (3 prong diode).
Checked the neutral safety switch...I think that's it... on the shifter? Good.
Tried to find a wiring schematic without luck...
Any ideas?
Thanks!
Any ideas?
Thanks!
