have been able to turn over engine but no spark... have checked spark plug and coil.! have limited power to back of coil but nothing going to spark plug... have fuel and checked engine stop and fine... ignition switch is working great ..!
Reverse switch is working...did ignition primary peak voltage.. all is fine but no spark to plug... but voltage coil is not 100v with readings... about 50dcA and 60dcA...??? ( connections to back of coil.) grounded plug to head no spark. new spark plug. Did continuity check with wires to back of coil to ECM all ok.. plug wire tests fine...
Ignition pulse generator checks and voltage all o.k... and 5P .7 minimum voltage.. more really..!
Starter relay is fine...! checked voltage Relay and all proper fine... wire and connectors fine...!
Battery is fully charges and cranks great and holds a charge well..
checks to fuse box and all fuses continuity o.k.....solenoid clicks and fine.. engine cranks great... battery voltage high...
check rectifier and alternator.. all checked out and voltage is fine... Stator or stating checks out with voltage and continuity.pulse generator is fine and voltage is good.
starter relay all checks out.!
transmission control motor checks out..!
I do not know what else to follow up or check and getting a little frustrated... Sorry for complaining but need advise...!! thanx....
jj
jj :|
Didn’t see a date on your post Wondering if you’ve any luck having no spark issues also
