1 - 7 of 7 Posts
Just got a 2003 Honda Rubicon 500 and it flashes d1 d2 and esp it worked the 1st night it was home with me and the next day for 2 hours then it wouldnt work in esp just start flashing all 3 d1 d2 an esp so i shut it off an did started it in d1 and it ran fine same with d2 but today i start it an it just flashes all 3 once again. Please help is it my angle sensor??
I'd start with getting yourself a service manual!
will tell you what codes flashing mean and to check!
there should be free down loads for manuals if you search here!
Discussion Starter #4
So the only thing im not getting is the code thing. It shows d1 d2 esp for 3 seconds an flashes it 5 times after. Would that be like a code 5 or something?
Sounds like it.
First thing you need to do on a Rubicon is make sure you have a good, fully charged battery with clean cable ends.
Download a service manual here.
https://drive.google.com/drive/folders/1GcqS65GYd3yFmEAGsI7LP-eZp2jMRVJU
Look under the transmission section for your machine, and it will give you error code diagnosis and troubleshooting instructions.
1 - 7 of 7 Posts
