Ever since I put my snorkel on from triangle atv, I have been having problems with it idleing properly. Also it has been backfiring through the carb between 0 to 1/4 throttle. what can I do. already adjusted valves and replaced spark plug.
yea, it runs fine with the stock setup. but I want a snorkel.
Ever since I put my snorkel on from triangle atv, I have been having problems with it idleing properly. Also it has been backfiring through the carb between 0 to 1/4 throttle. what can I do. already adjusted valves and replaced spark plug.[/quote
1 to about 1/4 throttle is controlled by your air/fuel mixture screw. try adjusting it. you may need to screw it in a little.
