motor problem help?
1231 Views 1 Reply 2 Participants Last post by  Yooperforeman
i think that my carb vent line sucked up mud the part i extended to snorkel was packed it ran top notch till a went in a deep rut whats the best way to get it out of the vent holes in the carb? i have checked everything else i know this in the problem. it runs but you hit the gas it dies, i have spark, never been swamped, i think carb is the prob? help!
Have you tried opening the carb. drain screw and letting the bowl drain out? I'd try that first.If that doesn't do it then you'll have to pull the carb. off the bike,remove the float bowl and clean it out.I've seen several that some junk in the bowl plugs up the main jet and that's the same symptom:It idles but dies as soon as you hit the gas.
