It's pretty straight forward... I've done dozens & dozens and I still use 4 boxes (that Honda parts come in.. approx. 12"wide 24" long 12' high) I put the top end parts in 1 box... Clutch parts (everything off the front of the motor) in another box.. Alternator parts (everything off the rear of the motor) in another box.. Then center parts (transmission ,balancer, crank etc.) in another box..
Do you have a shop manual..?..
The balancer timing line is hard to see when your putting it together ..I use a white metal paint stuff (in a small squeeze tube) to put a dot on the tooth with the timing line..
It helps to heat the cases when putting back together ..the bearings will drop in easy..
When you put the alt. cover on be careful the neutral switch has a "T" that runs it.. it looks like it will go either direction..but the "T" isn't in the center and if put in the wrong way it will break ..and you'll need a new switch .. Be sure the trans is in neutral ..line up the longer end of the "T" with the "N" written on the back of the neutral switch and you won't have any trouble..
Use "Three-Bond" or "Honda Bond" and not silicone to assemble.. The bottom end has only 1 gasket ..it's on the alternator cover the rest uses sealant..
Just msg if you run into trouble..
