1 - 19 of 19 Posts
Plowing this morning all of a sudden i could downshift past 2nd can't get 1st or rev but can upshift to 5th. Any help would be greatful.
Whats the clutch have to do with it not downshifting
i cant downshift with the motor off
Discussion Starter #5
I have never adjusted the clutch how do i know how far to adjust it
Discussion Starter #6
I just found picture on here about adjusting my clutch i will try it
loosen the jam nut then turn the screw counterclockwise untill you feel a little resisentnce then turn the screw 1/4 turn clockwise and tighten the jam nut (while holding the screw in place )
if the screw is seized in the front cover you will need to take the front cover off and free it up ........
Discussion Starter #9
Thanks i am going to try that
Discussion Starter #10
The adjusting bolts frozen to case thinks about just taking it to honda don't have the time to mess with it
Discussion Starter #11
I got a call from honda. theres a bolt that backed out of the shift drum they put loctite on and torqued to spec. My bill will be about $ 250.00
Discussion Starter #13
you were spot on thanks. the service guy also said this problem was more common on the 450 foreman is this true
yes the three things that i listed are the most common thing to mess with the S model foreman 450 or 500 (besides the clutch not adjusted correctly or at all )....good luck man
dang rich im always impressed how spot on you are all the time... impressive man. i wish i knew all that info
Welcome to the forum Mulefarmer. yes the ES models uses the same internal parts for shifting.
1 - 19 of 19 Posts
