THROTTLE LEVER FREE PLAY: 3 - 8 mm (1/8-5/16 mm)
Major adjustments are made with the lower adjuster.
Remove the seat ..Remove the resonator chamber by loosening the
band screw and removing the trim clip. Remove the two trim clips and turn over the rubber seal. Slide the rubber boot off the adjuster.
Loosen the lock nut, turn the adjusting nut as required and tighten the lock nut. Install the rubber boot securely. Recheck the throttle operation and install the removed parts in the reverse order of removal.
