whats the highest you can lift a 500 without putting the u-joints in a bad bind?
J jody · Registered Joined Jul 19, 2007 · 9 Posts Discussion Starter · #1 · Aug 13, 2007 Only show this user whats the highest you can lift a 500 without putting the u-joints in a bad bind?
S selah86 · Registered Joined Mar 5, 2007 · 360 Posts #2 · Aug 13, 2007 Only show this user i have HL 2" lift.... works good for me foreman has a SRA so its not really made to be lifted adding a lift will give you no more ground clearance
I iam500foreman · Registered Joined Aug 8, 2007 · 22 Posts #3 · Aug 13, 2007 Only show this user so what is the purpose of a lift then?? for bigger tires?
M MAD MUDDER · Registered Joined Sep 11, 2005 · 1,307 Posts #4 · Aug 13, 2007 Only show this user it will give you more in front but nothing in the rear. like selah86 its hard to get decent GC out of SRA bikes. -Aaron
S selah86 · Registered Joined Mar 5, 2007 · 360 Posts #5 · Aug 13, 2007 Only show this user yeah if u want bigger tires. its like putting a body lift on a truck, it sits taller but you dont gain any ground clearance.
G GTRider245 · Registered Joined May 9, 2007 · 103 Posts #6 · Aug 13, 2007 Only show this user Adding a lift allows for bigger tires, which in turn adds higher ground clearance. The lift itself doesn't do much though.
T trail_shredder_crf · Registered Joined May 31, 2007 · 111 Posts #7 · Aug 14, 2007 Only show this user but its a completly different story if u have IRS
