1 - 5 of 5 Posts
Hello have a 2001 foreman 450 local guy has a perflex off a 2002 foreman 450 will this fit on my 2001 when I Google it shows 2002 to 2005 but no mention of fitting a 2001.
Yes it should fit fine. You might have a wider or narrower lower shock eyelet but it will work.
I put a 450 Foreman Perfex on my 09 500. They're all pretty much the same.
Is the perfex lift kit better than the high lifter or super atv? New to this so just trying to do it right the first time if possible
Im not sure if one is better than the other. But I have a Preflex on myn and absolutely love it. I had the spacers on for a bit and it just stiffened the suspension to the point it was beating me up.
The prefex gives you a little lift and a much smoother ride.
The other lifts just give you lift.
Perfex is MUCH better.
I'm a tightwad but the Perfex is worth it.
1 - 5 of 5 Posts
