Just like to say thanks to this forum for the excellent info that enabled me to install an LED reversing lamp onto my new-to-me 450es last week :)
the job took no time, fitted lamp to base of my rear-trunk box, ran cable to battery compartment...
Fitted a four pin relay with lives direct to battery, switched live to lamp and the relay neutral wire tapped into the grey wire in the switch-block above / behind the pull starter
works a treat... now I can see behind me while trying to reverse in tricky spots while out shooting on our farm at night
Does that cause it to come on when you go to Reverse, or did you install another switch.
I'd like to see a picture of the lamp if you have one. And lamp detail.
