1 - 5 of 5 Posts
I did a little experimenting this weekend and I thought I'd share since I've looked all over the internet for LED upgrades for the lower 2 headlights on my 2006 Foreman 500. Basically all I did was take the base from my stock light bulb and put it on a a cheap amazon LED headlight. I kept the LED bulb wattage down as to avoid getting a fan cooled one. Its tight for space and I just done thin a fan cooled bulb is a good idea on a wheeler. I pulled the glass bulb off of my stock bulb, cut the plug off, drilled a hole through the base to suit my new bulb and I think I have a winner. I had to remove the wiring from my new bulb so I could get the existing base on. A little bit of soldering and it will be good as new. I haven't put them in my wheeler yet but I will post pics when I do. Figured I'd get this out there quick to give people ideas since you can't purchase an upgraded replacement.
Well did it work ? Looking to do the same thing. I was kind of thinking if you would cut the plug off of a junk car harness and solder the wires to the Honda ATV harness if you cut the special Honda ATV socket end off where you can straight plug and play
Has anybody else been able to rig up an led bulb to a 2008 Honda Foreman lower headlights. I already done the top light with an led it’s those aggravating specialized Honda plugs
I also noticed you only had two wires the foreman lower lights has three for high and low beam did you just cut one of the. Off or what
1 - 5 of 5 Posts
