is puting a dyno kit in makes a lot of different in power
J jeffrow03 · Registered Joined Apr 20, 2007 · 32 Posts Discussion Starter · #1 · Jul 15, 2007 Only show this user is puting a dyno kit in makes a lot of different in power
N natedizzer · Registered Joined Apr 4, 2006 · 290 Posts #2 · Jul 15, 2007 Only show this user not enough to write home about but you will notice better throttle response
C cormann2 · Registered Joined May 7, 2006 · 32 Posts #3 · Jul 21, 2007 Only show this user Maybe down on the low ground it dosen't make a diff,but riding from3 to 6 thousand feet it was like adding 100cc to the engine.
J joecamel · Registered Joined May 24, 2006 · 468 Posts #4 · Jul 21, 2007 Only show this user QUOTE ("jeffrow03":gc6pwxof) is puting a dyno kit in makes a lot of different in power Click to expand... the throttle response comes from the shorter, less stiff spring. the kit in itself wont do much that you can't do on you own. if you ad an air filter and pipe you can put a larger jet in and you'll notice a big difference in the power.
