I just installed a Triangle ATV snorkel on my bike and also re-routed my carb vent lines up to the pod. Once I did that, my bike won't idle and will die. It does it even when the bike is plenty warm from riding for hours. I'll just stop, click it down to nuetral and it dies. When I first ran my carb vents up, I just T'ed the two together and ran one line up to the pod. Thinking that that might be the problem, I removed the T and ran two seperate lines, but it would still die. I turned my idle speed up and it will run fine now, but just idles really high. Is there something that I need to check on so I don't have to have it idle so high to keep it running. Also, on a side note and another questioin......When my bike is warming up, and you give it a little gas with the choke on, it makes the engine really miss and makes a loud knock noise. Does anyone else's do that too?? Thanks for your help.
