Hey, I have a 2002 Foreman 450. I have recently gotten it outta of storage, the guy who stored it for me did'nt drain the gas out of it. So after workin' on it I finally got it running. But the promblem is, you have to choke it before it'll start and then you can drive it with the choke on but if you turn the choke of it will not idle. So with the choke turned on it will idle but as soon as you turn the choke off the atv quit's. If you turn the choke on and start moving then turn the choke off it will run but as soon as you stop if quit because it won't idle. I've took the carbarator off and cleaned it and I've cleaned every jet in it ( I THINK ) and I ran some Gumout carb cleaner and the promblem is still there. Can anyone tell me if i've missed a jet or somthing or what the promble may be.
