My bike has been sitting up and I cleaned carb, bike ran fine except it kept leaking out of bowl on ground.
I pulled the carb and float needle was unhooked so I fixed and reinstalled. Still leaked, so I read on here to blow air up hose and that would fix it (before I could read further down that said not to do it).I should have removed hose from carb before blowing it but I didn’t and now my bike keeps sputtering and dying unless I keep it on choke.
I removed carb again and there’s was trash in there from the blowing. I removed two jets and there was trash in there and cleaned them out and it’s still doing it.
Am I missing another jet or something else I should be cleaning???
Thank you in advance for any help.
Either you need a new bowl gasket if not then you may need a new float seat it may not be sealing and leaking out the overfill
