a custom lift will need to be made, extended a-arms, axles, swingarm, driveshalf and mounts for the shocks. the foreman can't handle a 4" lift in factory form.
the HL kit is only 2" tall and the lift springs and spacers will only keep the shock extended to there full lenght. A double lift will bottom out the balljoint and the axles. Even with the lift and springs, it will trash the inboard cup from the axle rubbing against the cir-clip that holds the cage inside it making it hard to replace a busted boot if and when it ever happens.
Honda Foreman Forums
