Check your battery to make sure it is holding a charge. Also, check to make sure that the wires are secure at the battery terminals. They may have vibrated loose, causing the battery to not give the full power the 4 wheeler needs. Iam sure that someone will chime in and let you know what the counted blinks mean. Good luck!
Russ
Russ
