I am in the process of inspecting my one way bearings in my clutch housing. Any idea on how keep the cam chain in a fixed position to loosen the clutch nut?
You can put a penny or a rag in between
the teeth of the big drive gears that are behind the clutches
That will hold both clutches in place and won’t damage anything
If you use an impact they will come off a lot easier without trying to turn the clutches, even without putting anything in between the gears
