how to adjust vavles on 2002 Honda Foreman 450
12229 Views 6 Replies 4 Participants Last post by  Honda Mechanic
G
Can someone let me know how to adjust the valves on my 2002 foreman 450?
1 - 7 of 7 Posts
Buy a service manual if you plan on doing the valves yourself. Its a lengthy procedure, too much to type here. Do a search on this subject in the forum. Someone did a step by step for a 500 Foreman which may help you some. Specs for both valves is 0.006".
just wondering is that spec 0.006" with the engine hot or cold
thanks for the info
is the 2003 the same for the valve specs
All years TRX450ES/S & FE/FM/TM set to 0.15mm (0.006in) for intake & exhaust ..
1 - 7 of 7 Posts
