G
Guest
·I'm trying to figure how much oil our Forman takes. The book says 2.5 quarts. That’s 2 and a half quarts right. Well I changed it today and put 2.5quarts in and it’s over the high level a little bit is that OK?
Thanks
Thanks
That is the correct amout with a filter change.
idle the bike for a few seconds the recheck the fluid level. make sure you are not screwing the dipstick in to check the fluid level. If you do, it will read high.
