All depends... The bottom drain tube off of the bottom of the carb is floor board level. If you plug this, then as deep as the air intake and carb vent tubes. Run these up under the pod and snorkle it and go as deep as you want. Ours always stalled until we stuck a stick or something in the drain tube..
