a few have been asking about how I have my fan hooked up using a three postion switch for it to work. here is a diagram to hook it up to run in manual, turn it off or run it factory. I am not an artist so bare with me. If you have any question about this setup, just ask. this will work on the 400 and 450 foremans. I am not sure of the setup on the 500's, but I would assume it would be the same.
if you look at the picture, on the rear of the motor where the thermo sensor is.
there is a blue wire that runs from the sensor to the frame behind the right rear tire. the wire can be dissconnected. Using a few wiring connections attach a wire to both ends and extend them to the pod to the 3 positon toggle switch.
the picture shows where to hook them. also a jumper wire will be needed as shown.
Next is a ground wire that needs to be grounded out to the frame somewhere up front.
As you can see there is nothing hooked on the center terminals of the toggle, as the center position will be used as the off position. When the toggle is put in the manual positon which will be in the down position, the red oil light will be on as well.
with the toggle in the up position it will be as if nothing was done to it and work as factory
