Ok so i just bought a winch for my 2002 honda rancher and there is a “accessories plug” or a car plug as i would call it and i have heard that you can just tap into those wires and run your winch off that instead of running all your wires too the battery wich would be a lot of work because there is so much plastics on it and also can i just buy a adapter that i can put my wires in and plug it into the plug or can i just splice into the wires behind the plug thanks
No you cannot run a winch off those wires. It draws WAY to Much amperage and will melt the wires to the accessory plug. You have to run the thick cables that should have come with the winch to the battery.
