I posted this reply in the Rubicon section earlier but figured it might be of use here too.
I know this thread is a month old but I figured someone sometime may be curious.
I'm in New Hampshire and we get SNOW! Then it warms up a bit and we have slush. Then it freezes again and the whole state is an ice rink. I researched spreaders quite a bit and only one of maybe a dozen different spreaders advertises that it can spread sand, the Swisher brand. The rest leave sand off the list completely without explaination. I assume it's because sand will cause problems in them.
The Swisher spreader sells everywhere for about $233 (the 150lb model for ATV's) but I Googled my a** off and found a place that sells them for $189.
www.outsideshopper.com
Friendly people, good price and quick shipping but - when I ordered about 2 weeks ago they said I got the last one and that Swisher was out of them too. Maybe more are ready now? I don't know.
Anyway, if you do any plowing this spreader is a must have companion. Assembly is a little tricky but straight forward (a helper would be great). Mounting wasn't bad either but again, an extra hand would be helpful while tightening the U bolts. I plan to make some quick-mounts to get it on and off quicker. There are three controls, two of which I wasn't especially thrilled with. First there is electric power to the motor. Just a 12 volt plug which you plug in and out for on and off. I would've preferred a switch, even an inline switch on the cord. The other control is the amount of material that flows out - from none to full. It's basically a sliding metal plate with a triangular hole. The problem is that to open it you have to be behind and to the side of the quad so you're dumping material before you start. A little wasteful.
I plan to make something slick to address both of those controls and will post details when I do. The other control is for width of spread. There are two knobs that you loosen, then slide the motor assembly up for smaller spread and down for larger spread (6'-14' I think). That works fine. KInd of set it and forget it.
There are a few extra holes in the metal parts that look like the designer may have been planning an add-on flow control, maybe with a lever or pull cable. I haven't seen anything like that yet but it could be a future availability thing.
If anyone has any questions just ask.
