The TRX350FM (foot shifter) model doesn't use an angle sensor ,the TRX350FE (electric shift) model does use an angle sensor .. What exact problems with neutral/reverse are you having ..
In 2000 -01 Honda had trouble with the shift drum breaking at the end where the gearshift indicator "T" locks into the shift drum.. This caused the bike not to show neutral when in neutral , and not to show reverse when in reverse .. So without the neutral light the bike wouldn't start ...
