There is no easy way to put the cylinder on.. Honda doesn't have a ring compressor for any of the ATV's ... We use 2 guys ,1 on each side of the engine with small long flat blade screwdrivers to help work in the rings .. The bottom of the cylinder is beveled in so the ring will automatically compress but it doesn't work very well on most cylinders .. You just have to keep the piston & cylinder square and be careful ..
