HMF Problem?
1219 Views 2 Replies 3 Participants Last post by  KAGRIFF
I just installed and HMF pipe and jetted it and everything i was ridein down the road wide open the other day and it back fired and just cut off... i got it started back up after a lil bit and it worked fine and then it cut off again it then cut off like 3 more times after that and the last i cant get it to stay cranked.. Im thinking I didnt jet it right can anyone supply me with some advice?
Tell us exactly what jets you used and what you did to the carb (adjustments). Did you use a Dynojet kit or just oem jet?
I have seen jets back out. soundss like this might have happened to you. bike will usally idle just barely but when you touch the gas it dies. just an idea
