1 - 6 of 6 Posts
i've got a used HMF pipe but i think its too loud.....can you buy just the core to put in them to make it quieter?
as long as the packing inside isn't damaged you can..if the packing is damaged you can send it off and have it repacked or order the stuff and do it yourself..
Discussion Starter · #4 ·
before i put it on i was moving it around and it sounds like there were pebbles rolling around in it.....should it sound like that or does that mean all the packing is messed up......? granted it is a used pipe, the guy wants 75 bucks for it and its loud. i'm just not so sure about the rocks in it.
the only way you can really tell is to just take the rivits out and take a look inside..it is very simple if you have a rivit gun..or you can pick one up at wal-mart for about 10.00..i beleive it's only about 25.00 for them to repack it..
i believe that hmf has a pretty good warrenty. i believe that ive reat that if you take it apart the warenty is voided. im not sure but check with them and see what you can do.
1 - 6 of 6 Posts
