I have a 2001 rubicon, went riding and after a few hours I put it in reverse and it sounded like you started it in gear and did not let go of the brake lever, put it in drive and it would not shift higher than 1ST gear in any range. checked codes got #11 at first then took angle sensor off to test and put it back on checked codes again got #6. dealer told me to install new angle sensor. I did and now when I do the initial setting prcedure and get to the throttle cycle the shift motor will not make a sound.display will not quit blinking "--". manual says idle for 30 seconds, drive slow 5 feet in D1, turn IGN off, turn IGN on making sure gear indicator is in "N", but digital gear indicator shows "--" not "N" ("N" light is on). tried to erase code can't do that either. started following flow chart without taking fenders off, continuity in both wires from ECM to the sensor, input voltage is good, resistance is the same at the sensor and ECM. the only odd thing I saw was that the manual says you have to line up sensor with the shaft then turn to line up screw holes, my sensor drop right on with out preload on sensor spring. removed control motor to see if reduction gear spins free, it did not spin with just a finger, so took scewdriver broke it loose and tried everything again with not a **** bit of luck. control motor bad, but sets angle sensor code? why code #11 first?
MAYBE TRADE-IN IS NEAR!!
please help SHES BEEN A GOOD HORSE
