ok this was my very first overhaul probably be my last too. Ok I got it put back together and in the 4wheeler it wouldn't start no spark the gear indicator would not work so I jumped a wire from the neutral wire to ground N light comes on hit starter and fires right up and sounds good. But can't figure out why the shift indicator switch won't work. It also won't shift with the electric shifter i can manually can i convert it to a manual shift book says not to use it as a manual only in emergency and troubleshooting. Also the clutch adjustment seems little weird as well if I remove the locking nut the adj. screw will move in& out w/out turning it. Thanks for any help
