1 - 1 of 1 Posts
Been working on my buddies 2012 Honda with esp and auto. Feel like I’ve been through the ringer with this thing. Code 11 won’t clear. It has blown the 30A fuse a few times though. Resistance is good through every wire I’ve checked. Control motor does nothing even during initializing. I’ve also taken it apart. Everything was clean and no sign of shorts. Machine only has 750 miles. I try to clear the code and it keeps coming back. New shift angle sensor. New gear position sensor. Now tps sensor. Any ideas? Shift indicator won’t show anything other than the code and it won’t cycle through any gear with the esp. I’m thinking the motor itself is shorted but it will turn both directions with a jumper wire..
1 - 1 of 1 Posts
