2018 Honda foreman foot shift. 4x4 was stuck and not disengaging. Replaced actuator and started working as it should Even though 4x4 would blink(ever since I got it) after fixing the actuator. Dielectric greased all the plugs for the 4x4 and relays and the small little black relays under the relays under the tank. Rode for 2 hours and back to stuck in 4x4 and will not disengage. I’m so confused. Fixing to sell the **** thing! Any suggestions?
It sounds like you could have a loose connection some where. First, I would wiggle each wire separately and try it after each one and if that didn't work, I would break out the voltmeter, put it on ohms and start checking connections. Hopefully you have the wiring diagram as I'm not sure there's for free online, for that newer model.
