I have a 2001 Honda Forman rubicon 500 and it is flashing D1,D2 and ESP while driving. It has no power in reverse and putt putt putts in reverse.
I did the code thing and it flashes all D1, D2 and ESP twice then break then twice again so I replaced the speed sensor with no luck.
Checked the connector for the speed sensor and it looks good with no corrosion
Help need some guidance or ideas.
Tks,
Matt
Try resetting the ECM and go from there. I had that on my 2003. Took it to a Dealer and 1st time they said loose/corroded connector. It worked for a few miles. Took it back to the Dealer and they replaced the angle sensor. Problem came back. This was over two years as my Rube stays at my Camp 8 hours away most of the year. Tried a new dealer this past fall. They replaced the ECM and properly indexed the angle sensor. 100 miles later no issues. I also had them adjust the valves which resulted in a much improved starting routine.
Zero out the ECM by resetting it and then take notice of the codes you are getting. I had an 11 then a 10. Also put dielectric grease on all connectors (lightly), If you have a service manual go through the troubleshooting procedures to narrow down the codes. Lots of You Tube videos on this. Good luck.
Just be aware that first year Rubicons have known transmission failures. I know this since I own one and went through lots of troubleshooting, hoping it was electrical. In the end it needed over 2 grand spent to get a new Hondamatic for it to run properly. Since newer quads are so expensive, it was worth it since the Honda is a great machine and wasn't worn out. Hope you find a fix and it doesn't break the bank!
