My 07 Foreman is the same way. Sometimes it shifts right back up out of R easily and other times I have to reach down with my hand and pull it up. Not sure why, it's pretty new so I figured it maybe had to loosen up a bit but I don't really know much about it. Any experienced insight out there?
My 06 Foreman does it also only when the bike is facing on a down slope. It seems like when their is pressure on the tranny it will not shift out of reverse.
I had the same problem and i just adjusted my idol down a bit. The problem is that the clutch assembly has to much pressure and it wants to hold it in gear. Give it a go if that doesnt work you can always use your warranty.
If it's new it's going to be tight, but all the suggestions here are good. I know on my ES if there is any pressure on the gearbox from being on a slope rocking the bike abit back and forth helps , and it just pops out no prob
1 - 15 of 15 Posts
