· Premium Member
This is not a big problem, but i wonder what could be causin' this? My
handlebars move just a little bit back & forth. They do not move side to
side. Is there a bearing in the steering mechanism? That's all i can think
it may be. Like i said, it ain't very bad, but it may get worse as time goes
on. Any idea's what it could be. Thanks.
RR if they are moving back and forth, remove the plastic cover on the handle bars, should be two phillip screws. There are two saddles that the bar sits in. The bolt head should be 12mm, maybe they loosened up alittle and tighten them might take care of your problem.
· Premium Member
Discussion Starter · #3 ·
Thanks Dirty. I will do that.
