Thats right. If you search the forum you can find the actual specs posted by Honda Mechanic. A lot of people adjust the tires straight ahead but they are supposed to be toed out to improve handling , especially at higher speeds.Just to clear this up for me...... the front of the wheels should be out just a bit more than the rear? Brain fart on my end.
Actually the front (Toe) of the front tires are supposed to be pointing outward 15mm.the FRONT of the FRONT tires are supposed to be pointing inward. so if you are looking at the bike from the front, they will be pointing at each other, only slightly tho
once u put weight on the bike them will straighten out
