I have a 2000 450es. I started to hear a slight poping sound in the front not bad and not all the time only when I turn. So I started to take a look at the front end. I noticed the on the right side of the bike the front axel shaft is starting to leak where the shaft mounts to the front diff.
So is this just a seal that will need to be replaced or is there a bearing and seal? I just want to make sure I'm looking for the correct parts. If some one could tell me how hard the repair is.
Here is a link to the fron drawing i think the part that needs to be replaced is item 53.
<a href="http://216.37.204.206/Mcmart/Honda_OEM/" target="_blank">http://216.37.204.206/Mcmart/Honda_OEM/ ... A=125&B=33</a>
One more thing I tried to remove the fill plug on the front diff and I guess the owner before my had stripped the head I tried for about and hour to remove the plug. Any ideals on how to get it removed. If flat out of ideals.
Thanks.
Thanks.
