1 - 7 of 7 Posts
aight was out riding last nite. im having a problem where the bike wants to pull hard to the right. like where i have to use muscle to actually keep the bike straight and when it stops pullin to the right i get a clunk sound in the front. havent taken it apart yet. gonna do that when i get home from work today. just seein if anyone has had similar problem. ill post more info after i get the front cleaned up and tires off.
Jack the front end up and grap the tire. Put your hands at the 12 o'clock and 6 o'clock positions and move the wheel back and forth (push in with one hand and pull out with the other). If there is play in it then your wheel bearing is probably out. Also take a good look at the cv joint boots and see if there is a tear in it. If there is it's most likely the one at the knuckle rather than the front differential. My buddy's '05 sportsman 400 started to pull really bad and was even locking up on him (and getting clunks) and he had to get a new axle for that side. The boot got tore and all the grease came out. More than likely it's gonna be one of the two. Let us know what you find out!
Discussion Starter · #3 ·
i know the bearin is bad..... that just went. but that bearing is on the left wheel. but the bike is pulling to the right. im think its an axle as well. will know something hopyfully tonight if i get a chance to start. thanks for the input.
Discussion Starter · #5 ·
lol i wish... it was doin this before i got them.. it stopped though so im like sweet nothing wrong. but now its back. so guess i should look into it.
ahh, tried the old "if i ignore it long enough it will go away" routine huh?
yep, Kelly has been trying the same thing with Euroboy. it hasnt worked yet either
Discussion Starter · #7 ·
QUOTE ("deadmullet":28q1aab5)
lol well it went away and i rode a cpl times and was fine.
1 - 7 of 7 Posts
