Front Drive Shaft
2032 Views 2 Replies 3 Participants Last post by  tjworthen
Has anyone had to do a front drive shaft seal at the motor end if so was it very involved??
Thanks
Chris
Not a big job .. We stand the bike on the rear tires & rear rack (turn fuel off and pinch fuel cap breather) ..Remove front wheels , unbolt (3) mounts for front differential and slide if forward and tie it .. Using a prybar pop the drive shaft joint off the motor .. Then using a pick/screwdriver dig the old seal out (careful not to mark the output shaft) .. Replace the seal keep it square as your tapping it in place ..
Good advice
That's sounds like a quick way of doing it.
