I have a 2006 Honda foremen 500 that whenever i go up hill in first the front end makes a popping sound a then stops and it only happens when I am in the mud and terming on the 4x4 or going up a hill .
I would do some research on front differential. If I remember right it might not be considered a serviceable part like the hondamatic. My differential blew through the side wall so was obvious.@bc buck ok do you think I should also open up the differential to se if anything else is wrong with it
They are serviceable based on the model I think he has.I would do some research on front differential. If I remember right it might not be considered a serviceable part like the hondamatic. My differential blew through the side wall so was obvious.
I would start by taking front end apart and inspecting everything from driveshafts out for damage. If all looks good and not joints at wheel(they will pop when going bad) then might need to open up carefully.
If thats his is way different than my 2002 rubicon.They are serviceable based on the model I think he has.
Honda ATV 2006 OEM Parts Diagram for Front Final Gear | Partzilla.com
Buy OEM Parts for Honda ATV 2006 Front Final Gear Diagramwww.partzilla.com
