When I hit the front brakes my left tire will lock up. I have checked the pads, ok, and adjusted the brakes as well. I noticed that while adjusting the brakes on the left front - when I would rotate the wheel it would drag in the same spot while the brakes are adjusted tight. Any one come across this problem. I read in the manual about a warped drum, Not sure where to go fromm here.
