Hello all I did try a search for this and found nothing on it. I have a 2002 Honda Foreman 450S has 1,300 miles on it. The front brakes harldy work at all and this weekend I was going to pull the front drums off and clean up things best I can. What due I need to look for and due?
I have another machine also that I ride with that has the same problem his is a 2003. Mostly Trail/Mud/crick bottom that they go through
Is there anything to look for while doing this would it help to Bleed the brake system? Can I use DOT3 Brake fluid from NAPA for this or does it have to be special from Honda?
thanks for your help on this.
I would rather just upgrade to Disc Brakes but I have a baby on the way and money will get tight as it is.
Any way here is a pic of the machine doing a little work back in july, I was back filling a trench dug from the garage to the house
